I try to boot CoreELEC from SD Card in a Minix U8K Ultra.
I used the Download helper and loaded the Image to a SD Card with etcher. I could not find the correct dtb File.
So I used the DTB file from the ne nightly Image.
renamed it and copied it to the root of the card.
But when I try to boot, I always only get to the Android recovery.
I also tried to use the nightly build directly with the dtb, but with the same effect.
Since I know that there are people running CE on the device I think there is something I have missed.
I tried booting by:
Reset button method → Recovery
Power button method → Nothing here
Reboot to CoreELEK APK → Recovery
If your SD card is correct, keep trying the power button method.
it probably won’t work the first time you try it, if you end up in android, shut it down with power menu, (select shutdown in the power menu) then try again.
Hold the power button for at least 10 seconds, maybe even longer, until you see the coreelec logo.
