Hi Folks. New to CE and the Forums. Haven’t yet tried a build, but looking to install on my Minix Neo U1.
Presently the U1 is running Libreelec with Kodi 16.1. Has worked perfectly for years, installed on eMMC. However I’ve just purchased a 4K TV & Receiver, and expect I need to upgrade to a new version for HDR support.
Firstly, I want to check that CE 8.95 will play HDR & regular 1080p content. Will it do that and handle switching between formats?
Next, is 8.95 stable enough, or am I better to go with a Kodi 17.6 version?
I’m running the wifi remote, so assume that won’t be a problem (looks like Minix IR remotes not OOB support anymore)?
Finally, can I export the video sources & database so I don’t have to rescan the entire library?
I’ve updated the U1 to CE 8.95.6, but was still running into issues playing HDR content. Regular 4K content was fine.
That’s going to lead me to begin another search for an HDR capable box
Any recommended units that jump out of the myriad of 905 boxes out there, preferably under £50? Or maybe that question is better for its own thread!
The challenge with that one is only 2.4GHz wifi, and 10/100 LAN.
For 4K I’m going to be looking for Gigabit (1000) LAN as well as 5GHz wifi (although wifi won’t be used much).
All S905X devices have 100Mbit/s network, because that is part of the SoC specification. I’m not sure about wifi, though.
But you can connect a 1GBit/s USB network adapter for a few bucks. You won’t have full GBit speed (I think it’s about 300MBit/s), because of the USB 2.0 restriction, but that’s more than enough for 4K/HDR.
But I think, the 100MBit/s interface covers 99,9% of all use cases, because even 1:1 bluray rips use a lower bandwidth.
Native 1GBit/s interfaces are only found in S905D (very expensive) and S912 (not properly supported in current kernel versions and future mainline kernel) devices.
Therefore - if the price is important for you - an S905X box (maybe with an external network adapter) is the right choice for you.
If you are ready to spend more than £100, you should go for an S905D one.
Don’t buy one of those new S905X2 boxes.
Although the specs are looking really nice, these devices aren’t supported by any JeOS including CoreELEC, currently.
