I only have 20 skins which i can install. Unfortunately not the skins i would like to have, i am looking for aeon or grid.
I already enabled " show incompatible", no effect.
I am using a mecool k2 pro.
Any ideas? Thanks!
Any ideas? Thanks!
https://forum.kodi.tv/showthread.php?tid=323909
https://forum.kodi.tv/forumdisplay.php?fid=142 you didn’t specify which Aeon.
Read the above links, you might be able to install manually
Looking for info I found this, and It worked for me
Regards
