Using 8.95.1 with MythPVR for livetv I notice the ability to FF REW SKIP PAUSE etc is missing. Controls are available and functional for all recording and other streams.
Seems there may be an issue with Kodi commit #14318 per Milhouse. Reverting that commit seems to fix the issue according to users.
This is a known issue with pvr.mythtv addon. It has been fixed in verison 5.8.5 of the addon. It should get picked up the next time the binary addons are rebuilt.
With DVBViewer Addon Timeshift Function āOn pauseā doesnāt work too.
I think its because there is no pause button, only the stop button, which is there when timeshift is disabled.
The buttons missing are the symptom. The addon author needs to modify the code and then Coreelec needs to rebuild the binary addons. Should be fixed then.
