2021-03-26 17:11:44.105 T:3667133312 ERROR: NFS: Failed to mount nfs share: (nfs_mount_async failed. Failed to start connection. Failed to start connection. Invalid address:. Can not resolv into IPv4/v6 structure.)
Strange it fails with any details on what it cannot mount.
I have 6 NFS mounts to various shares on my NAS and they are all working as they should.
Is there anyway of tracking down what might be causing this error?
Unfortunately that did not help either. However I have found out that whenever I stop playing a movie, tv show or even live FTA TV I get these 3 lines everytime:
2021-04-03 08:13:11.515 T:3258217344 ERROR: Unable to lookup host: 'folder.jpg'
2021-04-03 08:13:11.515 T:3258217344 ERROR: NFS: Failed to mount nfs share: (nfs_mount_async failed. Failed to start connection. Failed to start connection. Invalid address:. Can not resolv into IPv4/v6 structure.)
2021-04-03 08:13:12.561 T:3258217344 ERROR: Unable to lookup host: 'folder.jpg'
Possible some config or addon related.
If it doesn’t break functionality you can left it as is.
Or you can also try clean build on different usb/sd and check if you have this error again or not
