Mount Network Share
Hi all,
I would like to know how to mount an nsf share on my ODROID N2+.
I read and apply this topics without success:
_Mount Network Share - LibreELEC.wiki
_https://kodi.wiki/view/NFS
The following NAS configuration:
_191.168.1.17
_XIGMANAS
_Full address to share: 191.168.1.17/mnt/XL01/Share
systemd definition file
Description=nfs mount script
Requires=network-online.service
After=network-online.service
Before=kodi.service
[Mount]
What=/192.168.1.17/mnt/XL01/Share/
Where=/storage/Share/
Options=
Type=nfs4
[Install]
WantedBy=multi-user.target
Then start it for a test :
CoreELEC:~ # systemctl start storage-Share.mount
Job failed. See “journalctl -xe” for details.
Nov 17 15:45:28 CoreELEC systemd[1]: Mounting storage-Share.mount…
Nov 17 15:45:28 CoreELEC mount[3919]: mount.nfs4: remote share not in ‘host:dir’ format
Nov 17 15:45:28 CoreELEC mount[3918]: mount: mounting 192.168.1.17/mnt/XL01/Share on /storage/Share failed: Invalid argument
Nov 17 15:45:28 CoreELEC systemd[1]: storage-Share.mount: Mount process exited, code=exited, status=32/n/a
Nov 17 15:45:28 CoreELEC systemd[1]: storage-Share.mount: Failed with result ‘exit-code’.
Nov 17 15:45:28 CoreELEC systemd[1]: Failed to mount storage-Share.mount.
Thank’s for your help !!!
Follow the sample:
What=192.168.1.17:/mnt/XL01/Share
Exact :no_mouth:
I modified and now I’ve this
Any idea?
Nov 18 17:05:50 CoreELEC systemd[1]: Mounting storage-Share.mount…
Nov 18 17:05:50 CoreELEC mount[3712]: mount.nfs4: mounting 192.168.1.17:/mnt/XL01/Share failed, reason given by server: No such file or directory
Nov 18 17:05:50 CoreELEC mount[3704]: mount: mounting 192.168.1.17:/mnt/XL01/Share on /storage/Share failed: No such file or directory
Nov 18 17:05:50 CoreELEC systemd[1]: storage-Share.mount: Mount process exited, code=exited, status=32/n/a
Nov 18 17:05:50 CoreELEC systemd[1]: storage-Share.mount: Failed with result ‘exit-code’.
Nov 18 17:05:50 CoreELEC systemd[1]: Failed to mount storage-Share.mount.
You should first get to mount in terminal and then make systemd service.
mkdir -p /storage/Share
mount -t nfs 192.168.1.17:/mnt/XL01/Share /storage/Share
Looks like not exported folder to me.
We’re on the right track :star_struck:
So with your advices Share is mounted. That’s good !
But the mount is unavailable after reboot.
I followed the tutorial (https://wiki.libreelec.tv/how-to/mount_network_share) and created an automount :
_Disable the mount service in systemd
_Create a systemd .automount definition file
_Enable the automount service
_Reload systemd to apply changes
_Test the automount
As a result, the automount doesn’t work fine
Please see below the steps and the results:
systemctl enable storage-Share.mount
systemctl status storage-Share.mount
● storage-Share.mount - nfs mount script
     Loaded: loaded (/storage/.config/system.d/storage-Share.mount; enabled; preset: disabled)
     Active: active (mounted) since Sun 2023-11-19 07:03:36 UTC; 52s ago
      Until: Sun 2023-11-19 07:03:36 UTC; 52s ago
TriggeredBy: ○ storage-Share.automount
      Where: /storage/Share
       What: 192.168.1.17:/mnt/XL01/Share
systemctl status storage-Share.automount
○ storage-Share.automount - test automount for Share
     Loaded: loaded (/storage/.config/system.d/storage-Share.automount; enabled; preset: disabled)
     Active: inactive (dead) (Result: mount-start-limit-hit) since Sun 2023-11-19 07:01:48 UTC; 4min 31s ago
   Duration: 1min 12.136s
   Triggers: ● storage-Share.mount
Nov 19 07:01:33 CoreELEC systemd[1]: storage-Share.automount: Got automount request for /storage/Share, triggered by 3539 (kodi.bin)
Nov 19 07:01:35 CoreELEC systemd[1]: storage-Share.automount: Got automount request for /storage/Share, triggered by 3539 (kodi.bin)
Nov 19 07:01:47 CoreELEC systemd[1]: storage-Share.automount: Got automount request for /storage/Share, triggered by 3539 (kodi.bin)
Nov 19 07:01:48 CoreELEC systemd[1]: storage-Share.automount: Got automount request for /storage/Share, triggered by 3539 (kodi.bin)
Nov 19 07:01:48 CoreELEC systemd[1]: storage-Share.automount: Failed with result 'mount-start-limit-hit'.
:roll_eyes:
In CE under settings enable “wait for network” or something like that.
I seen in CE. There is this option “Wait for network”.
The value is 10s.
However, after each reboot Share is no available.
For example, with Putty, I run after reboot:
The result is:
× storage-Share.mount - nfs mount script
Active: failed (Result: exit-code) since Sun 2023-11-19 07:52:34 UTC; 8min ago
TriggeredBy: ● storage-Share.automount
Nov 19 07:52:35 CoreELEC systemd[1]: Mounting storage-Share.mount…
Nov 19 07:52:34 CoreELEC mount[3445]: mount.nfs4: mounting 192.168.1.17:/mnt/XL01/Share failed, reason given by server: No such file or directory
Nov 19 07:52:34 CoreELEC mount[3431]: mount: mounting 192.168.1.17:/mnt/XL01/Share on /storage/Share failed: No such file or directory
Nov 19 07:52:34 CoreELEC systemd[1]: storage-Share.mount: Mount process exited, code=exited, status=32/n/a
Nov 19 07:52:34 CoreELEC systemd[1]: storage-Share.mount: Failed with result ‘exit-code’.
Nov 19 07:52:34 CoreELEC systemd[1]: Failed to mount storage-Share.mount.
I have to white this commands again to mount Share :exploding_head:
Regarding the automount, I add this one, just to try:
[Unit]
StartLimitIntervalSec=0
