Mute HDMI audio output (when using SPDIF)
kann man das mit einbauen?
To mute try
echo "audio_off" > /sys/class/amhdmitx/amhdmitx0/config
To return:
echo "audio_on" > /sys/class/amhdmitx/amhdmitx0/config
but after a reboot the sound is on.
is it posible to make it permanent?
add this string to /storage/.config/autostart.sh
ok it works.
but is iz posible to make a option in coreelec options?
then it is easier to switch
