I bought Philips TV and find out that key_down button on my TV remote make turn my device to standby, red light (mecool). But dont turn it on again, only power buton of my mecool remote start it again. I used my own remote configured as MCE.
How i can disable specific button to make that action?
search for Remote Control. You must change the Settings or use only CEC. I past, i hava had the same problem with Odroid C2.
The TVButton Down ist he same, like PowerOff at the Player Device.
