Hi guys,
I have recently tried to enable my CE for an external MariaDB.
I have setup everything just fine on database side. I can connect from other clients using the same credentials as entered in the advancedsettings.xml file.
However, I am still getting this on startup of CE:
…2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos86 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos85 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos84 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos83 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos82 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos81 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos80 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos79 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.186 T:3982676848 ERROR: Unable to open database: MyVideos78 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.187 T:3982676848 ERROR: Unable to open database: MyVideos77 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.187 T:3982676848 ERROR: Unable to open database: MyVideos76 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.187 T:3982676848 ERROR: Unable to open database: MyVideos75 [2002](Can't connect to MySQL server on '192.168.11.54' (101)) 2015-01-01 01:00:18.187 T:3982676848 ERROR: Unable to open database: MyVideos116 [2002](Can't connect to MySQL server on '192.168.11.54' (101))
There are of course no DBs existing like that - it is the first time I am trying to do that setup.
I have also tried to connect to mysql using the direct mysql command inside the SSH shell:
mysql -u root -p <password> MyVideos116
I am getting the following:
-sh: mysql: not found
It appears that in CE 9.0.2 (at least on my machine), there is no mysql support at all as the binaries are missing.
What could I do in order to get this working?
Thanks for your help!
