N2+ : Exact same IR wakeup code works when sent from my phone but doesn't when sent from my Harmony Hub
I’m trying to configure an IR wakeup code on my N2+ as explained in this tutorial : How to configure IR wakeup code
But there is something I don’t understand. I’ve configured my Harmony remote to send the following IR code : Received IRMP code: remotewakeup='0x6f905583', decode_type='0x0', remotewakeupmask='0xffffffff' When I use ir-keytable -u, I can confirm by using my phone (my phone has an IR emitter) then the remote that both are sending the exact same IR code.
I have set that IR code to be the wakeup code.
And I don’t see why, but when I press that button from my phone it works and turns on. When I do the same on the harmony remote, it doesn’t.
I can’t find what is the difference between those 2 as the Odroid should be receiving the exact same code.
What do you think could cause this ?
Thanks in advance for your answer, have a great day.
Found it ! My problem was the duration for the code to be sent. Sending it more than 500ms is required, apparently, so I’ve adjusted it in Harmony settings and it works !
