Is it so hard to understand?
Everyone just write and ask without even try something by themselves.
This is exactly the case you need USB burning tool. It only require BL1 in the SoC itself, doesn’t matter if eMMC is empty or not. When it’s damaged the burning will fail.
### **Support (Dune HD)**
### Hello,
Thank you for your detailed request — unfortunately, we are unable to provide low-level recovery firmware or service tools.
Use the Amlogic Bootcard Maker tool on your computer.
Drag the u-boot.bin file from the working device (or extract it from the .img file you extracted using dd if you are experienced in partition extraction).
Use the tool to flash the bootloader onto the card.
Place the original firmware file (even if it’s a .dff file) or the dd version onto the card.
Insert the card into the faulty device and press the Reset button
then connect the power. If the device boots successfully, it will be ready for flashing.
I don’t actually know the exact name of the boot disk, but if there’s a way to extract it from my computer using the dd command, that would be great.
Thank you for your suggestion. I understand the process with the Amlogic Bootcard Maker tool, but since my device’s eMMC is completely wiped and I am unable to boot or access recovery, I need to take a different approach.
As you mentioned, if it’s possible to extract the bootloader and firmware using dd, I would like to kindly ask for your help in doing so via SSH.
Could you please follow these steps to clone the disk and send me the image?
Log in via SSH on the working device.
Use the following dd command to create a raw image of the device’s eMMC (or system partition):
(Replace /dev/mmcblk0 with the correct device path if needed.)
Once the image is created, you can transfer the image file to the USB drive and send it to me. You can also compress the file to make it easier to share.
If this is possible, it would be greatly appreciated as it would give me the image I need to restore the system.
Thank you again for your help, and I look forward to your reply.
Thank you so much for taking the time to do this for me. I truly appreciate your help and effort.
This is probably my last chance to revive the device. I will try to find a repair technician to write your dumped firmware image directly back to the eMMC and see if I can bring the box back to life again.
Without your help, I would have had no way forward at all. I’m really grateful that you were willing to help a stranger like me.
