Hello , i have installed CoreElec nightly for C5, thank you for that.
Noticed that the LED on Ethernet is flashing every second or so, even if the device is not being actively used. Is that a feature of CoreElec or could the device itself be at “fault”? There is not other software installed, just CoreElec-NO on a eMMC.
nada39, not very nice to insult this forum on other one!
If someone will have to say anything then you will get your answer.
peter, i am not insulting, just stating the fact. if i am not able to post properly, please correct me.
Your post is here. What else you want?
Why you went to LE forum if you don’t even run LE? Not to mention there is no LE image for this device.
My advice: ignore led flashing or try to identify the cause.
My advice for LAN led flashing
a) put your equipment in a cabinet, also results in a nice clean setup
b) use a black marker
c) use tape
d) unsolder it, if you’re capable
I don’t think there is anything in the software to stop a traffic indicator led
maybe you misunderstood me,
why would it flash every second or so generating traffic if it is not being used,
it just came online, doing nothing since booting up, but apparently it is working or snooping nonstop, otherwise why would the LED flashing all the time.
if it is just being “flashy” then so be it, but i thought it might be worth investigating. certainly i dont like data spies sitting around being active without being asked to do so. her in Europe better tech like good old incandescent lamp were being made illegal to be produced somehow for being “hot to the touch” yet we should accept fancy LED being invasive everywhere.
I don’t know the why’s but my router and ethernet connections flash all the time unless I physically disconnect them.
Maybe some other device in your network send a broadcast heartbeat.
Use wireshark and analyse your LAN?
I have similar if I use an wifi usb stick. My fix
Led dims or Light Dims. I use them a lot of leds around our place. Dark and not so dark. Can be doubled up.
the Odroid C5 running CoreElec.NO 22-alpha has LED flashing only on the right side (yellow-orange) but there seem to be another LED with green color, but it is not active.
the Odroid N2+ running an earlier CoreElec maybe Kodi Omega has LED flashing on the right side (yellow-orange) in similar fashion as C5, even when not used, and in adddition the left side LED on Ethernetport is green and always lit-ON when powered+connected.
I°d be glad to send data in real-time, to debug, but is there such a thing as a wireshark-extension for Kodi?
wireshark: https://www.wireshark.org/
tcpdump included in network tools addon: An introduction to using tcpdump at the Linux command line | Opensource.com
If you don’t know what to do ignore LED flashing.
Nobody here is going to debug your network traffic for you, you need to do it for yourself.
Otherwise, as vpeter said, just ignore it.
thanks for the pcitures, useful, but the case seem not covered,
(at least on the C5)
have another device n2+ connected to older bravia ccfl-TV;
it also does the LED-thing, flashing, also inside the case;
however, this one also wakes the TV after it has been turned off; after a few seconds, the TV turned automatically on again, although the CoreElec is not being used actively.
My proposal:
consider implementing a “Airplane Mode” that is persistent after reboot/shutdown and once activated, cuts/subdues the network activitiy, so that the device is effectively silent for the time it stays activated; it should
it would be nice if it could automatically disable the WireLess aswell, which is think should be made a requirement by law for all software/hardware;
on the Raspberry Pi it is a bit cumbersome to disable WiFi/Bluetooth, the Odroid N2/C5 fortunately does not have it, but a solution could be offered.
Just my two cents about this “issue”:
I have permanent connected CE device by LAN and there is no LED flashing when LAN is not used. So please check your setup or you installed any other harfull addon what can cause this.
Please contact the government of your country and provide such suggestion.
This is wrong, you can disable eth and wifi network in CE settings.
There are some solutions provided to “fix” the LED flashing so topic can be closed.
