Received my Nexbox A95X Pro last week (after waiting a month), today I killed it. Installing SuperSU under Android Nugget, in these boxes is a death warrant.
Anyway, while waiting for the supplier to furnish a firmware (hope they will), I figured I would install CoreELEC to see how it performs. First, I had to figure out which device tree to use that is in the folder that is included in the ROM. Of course I had to use google to find the CoreELEC downloads, couldn’t find them on this forum, what a pain looking for where to download that file.
Anyway, I just picked a device tree that LOOKED like it MIGHT work. Since this box comes with a RF remote that uses an external dongle, it worked right out of the box. Setup was a piece of cake and remote works great. WiFi, as expected does NOT work.
From my brief testing, my BlueRay rips are playing perfectly, with HD audio. Even my BlueRay rip of The Dirty Dozen, encoded in VC1 plays perfectly.
Installed tvheadend PVR client and it loads the guide fast, but when I switch to a live channel, the box powers off…
You don’t need google to find the device tree, they are all right there in a folder called ‘device_trees’ on the root of the SD card.
And this forum has a list of known boxes\device trees.
And how would I find that link, without knowing it was under the “News” section?? Forgive my stupidity, I am senile in my old age… Just that I struggled to find that ROM today.
I am running CoreELEC on some of my other Amlogic boxes.
This is the page I have bookmarked. When I check the posting on this forum, this what opens up… Now YOU show me which “button” to click from here to get to the screen you posted!!!
The link that was suggested by @Rascal is the one you said you was on. Have a look
Having now established you were, in fact, at a completely different site, I can see your confusion.
