Is it possible to have shortcut in the remote for next/previous subtitle? I only want to use 2 subtitles (external): one of the language I´m learning, and one of my native language, and I would like to be able to quickly switch between them
If it´s not possible, then a way to disable internal subs of the mkv, would also be great
You need to find the code for the button on the remote control that you want to use to change the subtitles.
Only the two subtitles you want to use should be in the file.
e.g.:
SUB1
SUB2
If the movie starts, there won’t be subtitles.
If you press the programmed remote control button, the SUB1 appears.
If you press the button again, the SUB2 appears.
If you press the button again, the SUB2 disappears.
If you press the button again, the SUB1 appears.
And so on…
That’s why I wrote that there should only be those two subtitles in the video. I don’t know any other solution. Maybe someone else can.
With mkvmerge that process is 1-2 min…to take out the unnecessary subtitles.
Did you try them separately?
Because you can’t have two separate keymaps with the same number (“61520”) in a single file, if it is not set to longpress.
And next time please use paste command for logs and don’t upload to forum. Or uload them to some online resource. We don’t have unlimited resources for such things. This applies to EVERYBODY.
