Hi there,
I have using mySQL/MariaDB to share Kodi library database for a while. My content are shared over NFS4, with following exports
nu22xj:~ # showmount -e 10.1.20.62
Export list for 10.1.20.62:
/nfs4_exports 10.1.20.0/27
/nfs4_exports/mMusic 10.1.20.8,10.1.20.7
/nfs4_exports/mShows 10.1.20.8,10.1.20.7
/nfs4_exports/mMovie 10.1.20.8,10.1.20.7
/nfs4_exports/4kHDR 10.1.20.8,10.1.20.7
I switched to NFS4 (as opposed to default v3) in the settiing and since it’s NFS4, the sources (in sources.xml
) are basically like this:
<source>
<name>Movies</name>
<path pathversion="1">nfs://10.1.20.62/mMovie/Action_Adventure/</path>
<path pathversion="1">nfs://10.1.20.62/mMovie/Charlie_Chaplin/</path>
<path pathversion="1">nfs://10.1.20.62/mMovie/Western/</path>
<allowsharing>true</allowsharing>
</source>
But when it rebulds DB, it’s getting all the path wrong:
MariaDB [(none)]> SELECT idPath,strPath,strContent FROM MyVideos131.path LIMIT 3 \G;
*************************** 1. row ***************************
idPath: 1
strPath: nfs://10.1.20.62/exPort/mMovie/Action_Adventure/
strContent: movies
*************************** 2. row ***************************
idPath: 2
strPath: nfs://10.1.20.62/exPort/mMovie/Bollywood/
strContent: movies
*************************** 3. row ***************************
idPath: 3
strPath: nfs://10.1.20.62/exPort/mMovie/Charlie_Chaplin/
strContent: movies
3 rows in set (0.001 sec)
It’s adding NFSv3 style /exPort
after the nfs-server IP, which is the actually root directory for NFSv4 now and shouldn’t be in the path. Not sure how it;s figuring out the server-side physical path but its invalid to a NFSv4 client, hence failling to payback any media at all.
Am I doing something wrong here? Or, did I miss anything in the config? Can anyone help me with this pls?
-S
