Just done today’s update on my N2 running from SD card and I’ve confirmed something I noticed the other day. When rebooting to apply the update, there’s no video output until the Kodi home screen reappears and the update has been applied. So all the messages about unpacking and updating the kernel and rebooting are unseen as is the CooreELEC logo on rebooting. I could only tell that something was happening by watching the red and blue lights while this was going on.
Subsequent reboots do not show the Coreelec logo too.
Let me know if there’s anything I can do to help you identify the reason.
Hello, I’m new to the forum, but I’ve been using CE (and LE before) for some years, from the times of S805. The latest months I’ve been using an Odroid N2, but I have still running some old Chinese boxes (S905X and S912).
Now I’ve got a new box to test this new builds. It’s another Chinese box, X96 Air, S905X3 2GB. It’s very cheap (22 €), so I don’t hope it’ll be perfect. Yesterday I installed CE on the box with a new uSD card and restored a backup from another box. No problem at all: boot ok, colors ok, wired network ok, remote database library ok, even TVH client works (server on another box). I don’t use wifi, bluetooth…
By now, the only problem I found is playing 4K files. The box is connected via an AVR (box --> AVR Denon --> Panasonic OLED TV). Playing HD files was ok, but when playing 4K files the image was black (the sound was ok). Also the TV didn’t show the video mode change.
I tried with whitelisting. When whitelisting only all 1080p modes, 4K file was playing ok, but in 1080p.
I tried disabling CEC (I don’t use it), but no success.
My last try was connecting the box directly to the TV and… it works, it plays 4K files with video ok.
So I think is an issue between the box and the AVR (it’s a Denon AVR2400). I’ve tested the same configuration with other boxes (N2, S905X and S912 boxes) with stable CE builds and never had such problem.
If needed, I could try installing the new build on the N2 to see if it works. Also could provide logs, of course.
You make a fantastic work. Big thanks.
Hi I have X96Max+ (4g,64g) I am running the “nightly_20191219” have changed the dtb to the one listed above (modified by “The Coolest” ) and can confirm that the display works perfect and that the gigabit lan is working, tested with “ethtool eth0” via SSH access. for anybody that needs wifi access I have tested with plug in usb wifi dapter and all works fine. Massive thanks to all the Coreelec team for their continued great work.
I tried and it works. Thanks. But then I had some other doubts.
Regarding the N2 configuration, I see it’s also configured as 4:2:2. I remember changing that config to test, but I think I played 4K from the first day with the default config. So I tried changing to 4:4:4 and it doesn’t work.
Regarding the AVR documentation, it’s clearly written that it’s capable of handling 4:4:4 signals. In fact, it has 2 modes for 4K format: standard and enhanced (this is for 4:4:4). And it’s in enhanced mode. Changing from enhanced to standard, and then again to enhanced, it gives me a message like “your TV it’s not capable of handling enhanced signals”.
So I go to the TV menu and search for ‘something’. Find an option called “HDMI Auto Setting”. It has 2 options, Mode1 and Mode2. The on-screen help says “if Mode1 doesn’t work change to Mode2”, and I do it. And now my N2 and my new box can play 4K files in 4:4:4 (both tested).
Thanks again.
I use X96MAX PLUS s905x3 4g/32g/1000M box playback some of 4k x265 remux HEVC video files, the kodi and CE will crash and automatic reboot.
Example for Zootopia.2016.2160p.BluRay.REMUX.HEVC.TrueHD.7.1.Atmos-FGT.mkv (43.9G), but eveything is ok when I use andriod kodi playback those files.
And I test from my the other old box (s905d, CE 9.20), still crash.
I tested it many times and every time it crashed in the same scene, for example, when the rabbit and the hippopotamus fought boxing, hippopotamus broke his own teeth and fell to the ground. In this scene, KODI must crash every time.
Even if I turned on the option: “Enable HEVC seek workaround”, the crash must still happen.
and I try to upload the kodi crash log to short url, but there is a bug, and I can’t upload it.
You said that playback almost all of Your 4k h.265 HDR files causing crashes and reboots.
But no logs etc.
Thats not submitting an issue, thats “mimimi”
