Thanks, that worked perfectly.
About hdmi mode setting in config.ini:
I run 9.2.3 on a N2.
Initial install was 9.2.2, then some nightlies, then 9.2.3 stable.
From my /flash/config.ini the âhdmi modeâ section is missing.
I did check the 9.2.3 image, and the newer config.ini indeed has that section.
Maybe the file was not updated on latest update?
Is it a known issue?
I suppose it is safe to just replace the file with the newer one, or manually edit/add the missing sections?
Or should I re-update or re-install?
Thanks.
The config.ini doesnât get updated after install, it also doesnât do anything until edited by the user so itâs default contents are more documentation of what you could add to the file, then specific sections.
If you just add the following to the end of the file it will have the same effect as if you uncommented the the line pointed to above.
hdmimode='1080p60hz'
Great, thanks.
Can you please enable kodi debug then remove your config.ini changes. Then set GUI to 4K and reboot. ssh to your box and pastebin kodi.log. Thank you.
I have a N2 and OLED 4K TV and I canât reproduce this.
Something went wrong with your sample. There is only black screen no matter which player I use.
Please make a better sample. Probably you need a bigger one. And please test it yourself if it shows your stutters. Also donât embed it here but send a download link.
Thank you
@Ray Here you go
http://ix.io/2qQb
And this is the screen after boot, Kodi seems to be running in the background
Check your Gui settings. You probably have the âresolutionsâ tags inside. I had them too again inside lately for a reason I canât explain.
Also can you post your resolution.ini?
Also do you use native 4K GUI or the scaled default one?
GUI 4K native.
resolution.ini
hdmimode=2160p60hz
frac_rate_policy=0
Yes, I have the resolutions section in guisetting.xml but removing them makes no difference.
Please try to disable native setting just for testing.
EDIT I could reproduce the issue with GUI scaling disabled.
Yep, setting Disable GUI scaling to off allows Kodi to run fine, albeit without a native 4K GUI
At least we narrowed it down. I will look why this is happening.
Thank you
Can that one be used to force 4K output? Iâve sometimes noticed that the box switches to 1080p, probably because the TV didnât manage to tell its capabilities on time. Itâs irritating having to check and possibly change the settings every now and then, especially with nightlies which require rebooting more often.
Iâm also having issues sometimes resuming playback of MPEG2 encoded videos, being inside mkv or an ISO. With ISOs, I always try to playback from the start because jumping directly to the point where I was just wonât work but you need to open the main menu. With mkvs, I select to resume but nothing happens. No âbufferingâ message whatsoever. Then after waiting for some time, retrying and this time choosing to resume from the beginning makes it work.
I think this started happening some time after v9.2.2 but Iâm not exactly sure. Which debug log options should I choose to make sure I catch this one in the log?
Yes because its only 5MB of 68501, you never said anything about a playing sample, just about some MB, thats what i provided.
When i provide a sample where i can check if it stutters (on the n2) then i need to upload not a few MB, then i have to upload many GB.
I also did not embed it in any way. I uploaded it to filebin and pasted the raw link here. If it auto-embeds, then this feature should probably be deactivated.
edit: have that file now, it is 50MB. i will take a look where i can upload it
https://wetransfer.com/downloads/45213f799e92481f19933ebdf2a71e7220200704144511/676d819356d46609513e6197b322d8a120200704144530/c46272
have you been able to download that file? its only there for (in total) 7 days, so it might be removed in the next days
since last update (nightly of today) coreelec is broken:
2020-07-06 11:41:50.070 T:4061573712 NOTICE: -----------------------------------------------------------------------
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Starting Kodi (18.7 Git:395c0b0649fcdc19c2f4dbaa53bb1e26305aeaca). Platform: Linux ARM 32-bit
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Using Release Kodi x32 build
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Kodi compiled 2020-07-06 by GCC 8.3.0 for Linux ARM 32-bit version 4.9.113 (264561)
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Running on CoreELEC (official): nightly_20200705 (9.2), kernel: Linux ARM 64-bit version 4.9.113 aarch64
2020-07-06 11:41:50.070 T:4061573712 NOTICE: FFmpeg version/source: 4.0.4-Kodi
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Host CPU: Amlogic S922X rev a, 6 cores available
2020-07-06 11:41:50.070 T:4061573712 NOTICE: ARM Features: Neon enabled
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://envhome/ is mapped to: /storage
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://home/ is mapped to: /storage/.kodi
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
2020-07-06 11:41:50.070 T:4061573712 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
2020-07-06 11:41:50.070 T:4061573712 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Local hostname: CoreELEC
2020-07-06 11:41:50.070 T:4061573712 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
2020-07-06 11:41:50.071 T:4061573712 NOTICE: -----------------------------------------------------------------------
2020-07-06 11:41:50.071 T:4061573712 INFO: loading settings
2020-07-06 11:41:50.072 T:4061573712 NOTICE: special://profile/ is mapped to: special://masterprofile/
2020-07-06 11:41:50.088 T:4061573712 DEBUG: CSkinSettings: no <skinsettings> tag found
2020-07-06 11:41:50.089 T:4061573712 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2020-07-06 11:41:50.089 T:4061573712 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<cputempcommand>/usr/bin/cputemp</cputempcommand>
<gputempcommand>/usr/bin/gputemp</gputempcommand>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<splash>false</splash>
</advancedsettings>
2020-07-06 11:41:50.089 T:4061573712 WARNING: CSettingsManager: missing version attribute
2020-07-06 11:41:50.089 T:4061573712 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2020-07-06 11:41:50.089 T:4061573712 NOTICE: Default Video Player: VideoPlayer
2020-07-06 11:41:50.090 T:4061573712 NOTICE: Default Audio Player: paplayer
2020-07-06 11:41:50.090 T:4061573712 NOTICE: Disabled debug logging due to GUI setting. Level 0.
2020-07-06 11:41:50.090 T:4061573712 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2020-07-06 11:41:50.090 T:4061573712 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2020-07-06 11:41:50.140 T:4061573712 NOTICE: PulseAudio: Server found running - will try to use Pulse
2020-07-06 11:41:50.142 T:4061573712 NOTICE: Running database version Addons27
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: driver.dvb.crazycat v9.2.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: driver.dvb.dvb-latest v9.2.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: game.controller.default v1.0.8 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: game.controller.snes v1.0.8 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: inputstream.adaptive v2.4.5.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: inputstream.rtmp v2.0.9.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: kodi.resource v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.album.universal v3.1.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.artists.universal v4.3.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.allmusic.com v3.2.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.fanart.tv v3.6.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.imdb.com v3.1.5 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.4 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.common.themoviedb.org v3.2.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.local v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.themoviedb.org v5.2.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.5.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: os.libreelec.tv v9.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: os.openelec.tv v9.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: peripheral.joystick v1.4.9 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.audio.radio_de v3.0.3 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.video.lastship v4.0.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.video.xstream v3.5.15.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.video.youtube v6.8.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.video.zattooHiQ v1.7.12 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: plugin.video.zattoo_hiq v2.0.14 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: pvr.iptvsimple v3.9.8.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: repository.cenightly v9.2 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: repository.kodinerds v9.0.103.103 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: repository.lastship v1.0.5 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: repository.xbmc.org v9.9.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: repository.xstream v1.1.4 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.amlogic.displayinfo v9.2.100 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.lastship.artwork v2.0.4 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.addon.common v2.0.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.certifi v2019.9.11 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.chardet v3.0.4 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.idna v2.8 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.inputstreamhelper v0.5.0 installed
2020-07-06 11:41:50.160 T:4061573712 NOTICE: ADDON: script.module.kodi-six v0.1.3 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.metahandler v3.0.2.2 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.myconnpy v1.1.7 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.pil v1.1.7 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.pytz v2014.2 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.requests v2.22.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.simplejson v3.16.1 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.six v1.13.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.tzlocal v2.0.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.urllib3 v1.25.6 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.urlresolver v5.1.4~nightly1 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.module.xbmcswift2 v13.0.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: script.program.driverselect v0.1.6.1 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: service.coreelec.settings v9.0.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: skin.estuary v2.0.27 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.addon v18.7 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.core v0.1.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.gui v5.14.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.json v10.3.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.python v2.26.0 installed
2020-07-06 11:41:50.161 T:4061573712 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2020-07-06 11:41:50.186 T:4061573712 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2020-07-06 11:41:50.241 T:4040676224 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2020-07-06 11:41:50.242 T:4040676224 NOTICE: Found 2 Lists of Devices
2020-07-06 11:41:50.242 T:4040676224 NOTICE: Enumerated ALSA devices:
2020-07-06 11:41:50.242 T:4040676224 NOTICE: Device 1
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_deviceName : @
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_displayName : Default (AML-AUGESOUND Analog)
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_displayNameExtra: PCM
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_channels : FL, FR, LFE, FC, BL, BR, BLOC, BROC
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_streamTypes : No passthrough capabilities
2020-07-06 11:41:50.242 T:4040676224 NOTICE: Device 2
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_deviceName : sysdefault:CARD=AMLAUGESOUND
2020-07-06 11:41:50.242 T:4040676224 NOTICE: m_displayName : AML-AUGESOUND
2020-07-06 11:41:50.242 T:4040676224 NOTICE: Device 3
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceName : surround71:CARD=AMLAUGESOUND,DEV=0
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_displayName : AML-AUGESOUND
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_displayNameExtra: HDMI Multi Ch PCM
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_channels : FL, FR, LFE, FC, BL, BR, BLOC, BROC
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_streamTypes : No passthrough capabilities
2020-07-06 11:41:50.243 T:4040676224 NOTICE: Device 4
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceName : iec958:CARD=AMLAUGESOUND,DEV=0
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_displayNameExtra: S/PDIF
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16NE,AE_FMT_S16LE
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
2020-07-06 11:41:50.243 T:4040676224 NOTICE: Device 5
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceName : hdmi:CARD=AMLAUGESOUND,DEV=0
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2020-07-06 11:41:50.243 T:4040676224 NOTICE: Enumerated PULSE devices:
2020-07-06 11:41:50.243 T:4040676224 NOTICE: Device 1
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_deviceName : Default
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_displayName : Default
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2020-07-06 11:41:50.243 T:4040676224 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2020-07-06 11:41:50.271 T:4061573712 ERROR: GetString: error reading /storage/.kodi/userdata/disp_cap
2020-07-06 11:41:50.275 T:4061573712 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
2020-07-06 11:41:50.275 T:4061573712 ERROR: GetString: error reading /storage/.kodi/userdata/disp_add
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 30.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 29.970030 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 25.000000 Hz
2020-07-06 11:41:50.276 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 24.000000 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 23.976025 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 4096 x 2160 with 4096 x 2160 @ 24.000000 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 4096 x 2160 with 4096 x 2160 @ 23.976025 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 50.000000 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 60.000000 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found resolution 3840 x 2160 with 3840 x 2160 @ 59.940060 Hz
2020-07-06 11:41:50.277 T:4061573712 NOTICE: Found (3840x2160@60.000000) at 41, setting to RES_DESKTOP at 16
2020-07-06 11:41:50.278 T:4061573712 NOTICE: EGL_VERSION = 1.4 Bifrost-"git"
2020-07-06 11:41:50.278 T:4061573712 NOTICE: EGL_VENDOR = ARM
2020-07-06 11:41:50.278 T:4061573712 NOTICE: EGL_EXTENSIONS = EGL_KHR_partial_update EGL_EXT_image_dma_buf_import EGL_KHR_config_attribs EGL_KHR_image EGL_KHR_image_base EGL_KHR_fence_sync EGL_KHR_wait_sync EGL_KHR_gl_colorspace EGL_KHR_get_all_proc_addresses EGL_IMG_context_priority EGL_KHR_no_config_context EGL_ARM_pixmap_multisample_discard EGL_ARM_implicit_external_sync EGL_KHR_gl_texture_2D_image EGL_KHR_gl_renderbuffer_image EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_KHR_gl_texture_cubemap_image EGL_EXT_create_context_robustness
2020-07-06 11:41:50.278 T:4061573712 NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_client_extensions EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses
2020-07-06 11:41:50.288 T:4061573712 NOTICE: Checking resolution 16
2020-07-06 11:41:50.288 T:4061573712 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
2020-07-06 11:41:50.298 T:4061573712 ERROR: failed to create window surface (EGL_BAD_NATIVE_WINDOW)
2020-07-06 11:41:50.298 T:4061573712 FATAL: CApplication::Create: Unable to create window
2020-07-06 11:41:50.299 T:4061573712 NOTICE: Stopping player
2020-07-06 11:41:50.299 T:4061573712 NOTICE: Storing total System Uptime
2020-07-06 11:41:50.299 T:4061573712 NOTICE: Saving settings
2020-07-06 11:41:50.310 T:4061573712 NOTICE: Saving skin settings
2020-07-06 11:41:50.310 T:4061573712 NOTICE: Stopping all
2020-07-06 11:41:50.314 T:4061573712 NOTICE: stop dvd detect media
2020-07-06 11:41:50.314 T:4061573712 NOTICE: Application stopped
just tried the old version (from 3.7) but i have the same behaviour.
i see the coreelec logo on the upper left but thats it, no kodi etc.
running now: CoreELEC-Amlogic-ng.arm-9.2-nightly_20200626.tar
that works
Yes I downloaded your sample. I donât see any issues with my N2.
