Don’t know if it is Kodi or CE. Odroid N2 Oled Driver 0.1.3 by roidiy.
I reverted to 190530 which was best for me so far. Ethernet link is up in 5 sec, Oled display turns on instantly with correct time, no double NF info only standard “Background Service Started”…
Can you take off 190531 to stop nagging me with update until you fix kernel?
When home screen comes up the first sign that ethernet is up and box is online is correct time showing on Oled display. (I have no onboard clock battery so after power on it shows wrong time if it’s not online) Proper time shows about 4 secs after Home screen comes up. Next is, about a sec later, NF info for background service. Next is, also about a sec later Weather icon in the top right corner below the clock display. So I conclude that it takes about 4-5 secs to get online, maybe shorter…
With latest knightly these times are at least 6 seconds longer.
Like i do, yes weather service can take sometime to show… maybe due to extension be loaded, or/and Yahoo response time.
So this part can be a bit irrelevant…
Clock time is a better indicator
In my case Medias are on a NAS… so when scanning, means it fully online.
I do believe you about the delay but it is a bit subjective to measure this way. I don’t see any delays even with Netflix. I’m just thinking of a way to reproduce or measure hmmmh.
I agree, and had never intention to measure this time correctly, just observe how and when mentioned things show/appear.
But 6 seconds delay between these two knightlies is easily observed.
You mentioned that you use “wait for network”, I don’t use that, really no need for it…
I have a mysql db so I need it. Just give it a try. What’s the worst that could happen?
Back in the days I was the one making first testbuilds for LE when the guys developed the Netflix addon and this option was always required!
Aaah, have no NAS or mysql db so this 5-6 secs after Home Screen don’t bother me enough to use that option. Sometimes I boot the box without online connection, just to watch something from USB HD…
