Success: booted with microSD, copied CoreELEC-Amlogic-ng.arm-9.2.0.tar to backup folder on microsd running corelec. Used putty to access coreelec and copied the .tar to var/media/STORAGE/.update.
Removed micro sd and booted EMMC, updated in boot and booted up nicely to stable 9.2.0
sorry, but how do I restore it on Odroid N2, the instructions are too fuzzy for me.
CE is running on the sd card but looping cause of the faulty nightly.
TheCoolest I see SYSTEM and KERNEL on the tar but the mSD has a file called KERNEL.img not just KERNEL.
Do I need to rename it or delete the kernel.img?
Hi mates, I saw on sale the magicsee N5 max with s905x3 cpu. Is the nightly next generation build ready to run with the next one generation cpu?? Thanks in advance, regards
