Nightly builds
cat/proc/device-tree/amlogic-dt-id
should i do this
X3 Amlogic S905X3 4 GB RAM 64GB ROM 1000M LAN 5G WIFI bluetooth 4.0 4K 8K Android 9.0 TV
changing audio output from hdmi to hdmi multichannel pcm fixed the sound
Are you refering to what version should you download?
For S905X3 you should use coreelec-ng, the one with img.gz extension to burn it into a sd/usb. And use the device tree with the specs of your box.
This is the channel from the playlist with “Pomoyka”. Piracy in question?
PS: on the official firmware this effect is not.
P.P.S. The channels worked on their own, what was it?
English is not my native language. I may have written it wrong.
Yes, which version do I need to download? I asked that.
Thank you for your help…
edit:
Is this the right link for me?
https://relkai.coreelec.org/CoreELEC-Amlogic-ng.arm-9.2-nightly_20200108-Generic.img.gz
Yes the Generic NG is correct.
Yes, that’s it.
Now burn that image to a sd/usb with rufus, and take the correct dtb from the device trees folder.
Put it on root folder and rename it to dtb.img
With nigthly buil 20200108
the temperature of the x96 air (s905x3) has dropped 10-12º. Thx, great work.
Anybody knows what speed can work the slot of microsd in an TvBox?
Yes, me. Read this:
That’s the same issue I mentioned earlier in the thread. It’s like the auto conversion of AAC to PCM doesn’t work when HDMI is selected. When I changed it to PCM everything worked, but my two other boxes don’t exhibit this behaviour on the stable build.
@Alestilohomer and @kostaman
Thanks for your help.
Works well…
Hi guys , I’m very please with the latest nightly on my gt king and right now for my use I’m not find any playback and/or other issue .
The only strange thing is that It seems the auto update prompt does not show anymore , I’m on 03/01 nightly and even using custom channel I can’t find the new nightlies , am I missing something ?
Where did this image go?
https://relkai.coreelec.org/archive/CoreELEC-Amlogic-ng.arm-9.2-nightly_20200108-Generic.img.gz
@Erario when a new nightly gets built the previous nightly gets moved to the archive folder.
Cool thanks!
But I don’t understand why in the last night build I don’t find support for S905X3, or I can’t find the correct dtb for S905X3 4Gb 1Gbit anymore (filename sm1_s905x3_4g_1gbit).
Did you download the amlogic-ng build? Since if you did download the right build that dtb file should be there.
Unfortunately if you downloaded the 20200110 build there is no right option since there was a technical issue that prevented the amlogic-ng build from compiling last night. so the build I linked to is the newest available build to support your device.
I just tried the 20200108 build and my multi-channel audio issue is fixed, unfortunately the display is like this:
Is this a known issue? I couldn’t find anything that would fix this.
I refer to the slot itself. How fast can stand it?
