Hi guys, I’m new at this intresting forum.
I bought an X96 Max, just for use with kodi instead of the Rpi and Rpi2 and I have been doing some speed tests of storage access speed of this “Cheap Chinese” TV Box that works very well with CE 9.2.1.
Hope you, like me, find it intresting. SD adaptor sucks. Don’t waste money on fast and expensive SD cards with this box. I will try to run CE from a Samsung MUF-128AB, which is very small and fast. Boot CE from a SanDisk Extreme USB 3.0 is lighting fast, allmost as fast as using emmc with less problems.
CoreELEC (official): 9.2.1 (Amlogic-ng.arm)
Internal EMMC Write Speed mounted on CE running from a SD
CoreELEC:~ # dd if=/dev/zero of=/tmp/mnt/test.tmp bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 7.072257 seconds, 144.8MB/s
Internal EMMC Read Speed mounted on CE running from a SD
CoreELEC:~ # dd if=/tmp/mnt/test.tmp of=/dev/null bs=1M
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 6.665528 seconds, 153.6MB/s
SD Write Speed (Sandisk Extreme Pro 170 - with kodi working)
CoreELEC:~ # dd if=/dev/zero of=test.tmp bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 30.265264 seconds, 33.8MB/s
SD Read Speed (Sandisk Extreme Pro 170 - with kodi working)
CoreELEC:~ # dd if=test.tmp of=/dev/null bs=1M
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 57.697327 seconds, 17.7MB/s
SD Write Speed (Sandisk Extreme Pro 170 - with kodi sopped)
CoreELEC:~ # systemctl stop kodi
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 30.719815 seconds, 33.3MB/s
SD Read Speed (Sandisk Extreme Pro 170 - with kodi stopped)
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 59.322468 seconds, 17.3MB/s
SD Write Speed (Samsung 32 PRO - with kodi stopped)
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 33.449927 seconds, 30.6MB/s
SD Read Speed (Samsung 32 PRO - with kodi stopped)
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 50.752683 seconds, 20.2MB/s
HDD Write Speed (WD My Passport 1TB USB 3.0 NTFS)
CoreELEC:~ # dd if=/dev/zero of=/var/media/My\ Passport/test.tmp bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 12.536652 seconds, 81.7MB/s
HDD Read Speed (WD My Passport 1TB USB 3.0 NTFS)
CoreELEC:~ # dd if=/var/media/My\ Passport/test.tmp of=/dev/null bs=1M
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 11.373092 seconds, 90.0MB/s
USB 3.0 Write Speed (SanDisk Extreme 3.0 USB 64GB)
CoreELEC:~ # dd if=/dev/zero of=/var/media/SanDisk/test.tmp bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 5.609796 seconds, 182.5MB/s
USB 3.0 Read Speed (SanDisk Extreme 3.0 USB 64GB)
CoreELEC:~ # dd if=/var/media/SanDisk/test.tmp of=/dev/null bs=1M
1024+0 records in
1024+0 records out
1073741824 bytes (1.0GB) copied, 8.175669 seconds, 125.2MB/s
