I tested this now with 2 different fresh untouched Installations on SD Cards
and three different TVs
In Settings-System-Display-Resolution 1920x1080i is listed.
If I try to activate this resolution then nothing happens!
As a follow up no 1920x1080i options are listed in whitelist.
Only way to get Display Resolution to 1920x1080i is manually editing the guisettings.xml
Didn´t have this with Ce before last release
log-2018-06-10-11.37.24.zip (58,8 KB)
edit : I think can be closed, because Raybuntu told me in german that this is a KODI problem.
