I recently purchased an Odroid N2 and am using the latest CoreElec Nightly build. So far most everything is fine, but I just discovered that I’m not getting any audio on my security camera’s RTSP streams. Video is 1080p / H265, audio is AAC. Cameras are Dahua.
The preamp says the system is outputting 2-ch PCM, as does the HDFury in the middle, but I only get silence. I’ve played around with enabling / disabling passthrough, switching from optimized to best match to fixed, and changing the number of channels to no effect.
This worked fine in previous editions of Kodi/LibreElec on a Chromebox, and also works fine on a current Kodi running on Android TV hooked up to the same audio system.
Debug log at http://ix.io/25fT
Look for “Keeley” as the stream name.
