I have s905x3 box that runs 20.1. After changing the coreelec setting from auto to 4:2:0 there is no display even after reboot. I can still access the device via ssh. Can I revert the command via ssh?
Remove resolution.ini
on COREELEC
partition. After boot set it to auto again and reboot again.
CoreELEC3:/flash # rm resolution.ini
rm: remove ‘resolution.ini’? Y
rm: can’t remove ‘resolution.ini’: Read-only file system
is above correct? can’t seem to delete it.
You first need to make the flash area write-able by remounting it:
mount -o remount,rw /flash
Thanks. that worked
CoreELEC3:/ # mount -o remount,rw /flash
CoreELEC3:/ # cd /flash
CoreELEC3:/flash # reboot
