Hi there,
Just brought my Qbox back to life with the latest CoreELEC. It’s working, but i have no remote. I read some difficult stuff to get remote.config working, but I’m looking for a n00b tutorial…I have putty; i have an ip…but putty doesn’t connect…
This might or might not work. From the repo (search forum for remote files)
Copy remote to storage\configfiles renaming to remote.confSunvell_T95K_Pro_conf.zip (1.3 KB)
type \\ipaddress into windows explorer address bar to get to configfiles
obviously, unzip first.
If this doesn’t work, you will need to create your own reading the documents in the repo
