NO: VIM3 - playback does not start
I have a somewhat weird issue with my Khadas Vim 3, where playback does not start.
To be precise, this only appears when a delay after display mode switching is set. In my case, I need to set a delay of about 2s to mitigate problems with audio not playing. (LPCM and passthrough)
Starting playback with a delay set in the settings results in a stuck image (the first frame of the file) until “something” changes on screen. This can be a small movement of the cursors or a key press. It does not matter what content (1080p/4k/sdr/hdr) is used. It happens with all of them.
When having debug logging on with the info on screen, everything works, so the changing debug info overlay text on screen is enough to trigger a change, so playback starts.
I’m only seeing this problem with my VIM 3. I also have an X96 X10 Pro, where I also have a delay of 2s set. Everything works fine there, no keypress etc necessary… So this must be a VIM3 /A311D issue.
I created a Kodi debug log (loglevel 1 through advanced.xml) and also the dmesg output.
It would be awesome if this could be fixed! Thanks! Please let me know if there is something needed…
kodi_vim3_bug_debug.log (730.6 KB)
dmesg-out-1.txt (80.7 KB)
device: Khadas Vim3 Pro
version: 22.0-Piers_nightly_20251017 (not specific to this version)
##Edit:
After further looking into this issue, it seems that somehow the driver does not send a correct vsync signal, and Kodi is stuck at CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: true
Is this an issue with Kodi or really a kernel/driver issue? Who (regarding the CE team or the Khadas guys) can/is able to fix this?
There is no error in log to find.
So you maybe need to try to flash a newer Android on VIM3 first and then try again with latest CE-NO nightly.
May I ask if someone could take a look at this issue (a potential driver bug, I guess?) with my Khadas VIM3? => NO: VIM3 - playback does not start
Or is this something I should post in the Khadas forum?
Thanks for your reply! I will try a newer android and retest. May I ask how a newer android should help?
This issue is also present with a VIM 4… Regardless of Android version, it occurs… So this must be a Bifrost G52 Mali issue…
I tried setting a 2sec delay, and setting the audio 2sec ahead with LPCM audio on the VIM4 with 2025-12-12 CE-NO nightly. I wasn’t able to replicate the screen freeze.
Have you tried the VIM3 or VIM4 on another television in case the freeze is happening on the TV side. Maybe it’s a television, or television + device issue?
Hmm, I will retest this with a different TV set/monitor.
What do you mean by 2sec audio ahead?
I was referring to this => https://kodi.wiki/view/Settings/System/Display#Delay_after_change_of_refresh_rate :eyes:
I have now tested it on a different TV (a simple 1080p monitor, no avr, just a direct HDMI connection) and the issue is the same.
