Nordvpn with kodi Token entry
V very happy new year to you all
I’m very happy with CoreELEC running kodi, but I couldn’t get in to mt Nordvpn account on a laptop and had to change my password. . So the token used in kodi for nordvpn, is no longer valid ..
Entering a 64 character token with the TV remote is a long tedious process.
I can ssh in to the OdroidN2 running CoreELEC and I can access the .kodi/service.vpn.manager/Nordvpv
and using GFTP I can see the ovpn file and the pass.txt, the later is empty.
Is the location of pass.txt where the nordvpn token should go ??? , if so I should be able to SFTP a new token to that location .
thanks
No it is not, I’d like to find the location file for updating still
From ssh stop kodi using;-
systemctl stop kodi
Open this file:-
.kodi/userdata/addon_data/service.vpn.manager/settings.xml
Look for this line that contains your old token and replace with your new token:-
<setting id="vpn_token">your_old_token</setting>
Then save the file and restart kodi:-
systemctl start kodi
Nordvpn have changed their authorization method and the kodi vpn manager no loner works with a token.
Connecting to any of Nord’s servers requires credential s, NOT a token, any attempt to use kodis vpn manager deletes pass.txt.
Credentials are on your NordVPN desktop page
https://my.nordaccount.com/dashboard/nordvpn/manual-configuration/service-credentials/
A work around is to add in /storage/.config a file autostart.sh
openvpn --config /storage/.kodi/addons/service.vpn.manager/NordVPN/United\ States.ovpn &
My current CorecELEC vesion is Nexus
