I am not able to connect to any Wifi network on this TV box: Mecool M8S Pro L
I am using the latest CoreELEC 9.2.1 (but this problem was happening on 9.2.0 as well)
When navigating to “Settings” > “CoreELEC” > “Connections”:
when choosing the Wifi network from the list, after typing the password, I see CoreELEC is trying to connect because there is a lable that changes from idle
to connect
(or connecting
don’t remember). After a few seconds I briefly see it becoming failed
, then going back to idle
Checking the logs at /storage/.kodi/temp/kodi.log
I see the following:
2019-11-30 15:13:10.761 T:3669746496 ERROR: ## CoreELEC Addon ## connman::dbus_error_handler ## ERROR: (Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
2019-11-30 15:13:10.761 T:3669746496 ERROR: None
2019-11-30 15:15:00.954 T:3669746496 ERROR: ## CoreELEC Addon ## connman::dbus_error_handler ## ERROR: (Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.)
2019-11-30 15:15:00.955 T:3669746496 ERROR: None
- what’s wrong with what I am doing?
- is this a bug or do I have to connect in a different way?
