Lestat
8 December 2023 17:42
1
hi all
this morning i had a running CoreElec CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20231031-Generic.img using that image on a Homatics Box R 4k
after the power cut its now stuck in a boot loop with
this displayed on the screen
is this recoverable or do i need to start again from scratch?
Try to place a tar in the update folder while it’s plugin PC and maybe the update do repair it itself on next boot. If not clean fresh install, yes.
Lestat
12 December 2023 12:03
3
lucky for me i had still had the CoreElec zip file and copying the files on there on to the root of the USB drive fixed it for me
1 question this is the first time i have used the nightly builds and i have auto update turned on but i noticed that my version had never been updated
is this something you have to do manually with the nightly builds
am only using the nightly so i can use DV
system
Closed
12 March 2024 18:03
4
