I had installed nvme into my box and I don’t access disk. Nvme is more small and more integrated.
Can you integrated drivers ?
kind regards
kind regards
The KVIM3 in CE is configured to have a USB 3.0 port, not NVME. You can only have one or the other.
The concern is that the user can remove the hard drive via USB.
If we want a nickel box, I have to put the disc in a case. This means that it doubles the volume compared to a nvme box.
I look at the products on the market, the biggest competition is “Fire TV Stick” even if it is not the same thing. We are really going towards compact, so that it can be used for no-geek
I use khadas-vim3 uboot and dtb (from khadas ubuntu project, offically support nvme SSD) to boot coreelec.
Still can’t see NVME disk.
What should I do next? change kernel configuration file?
