Odroid C2 and USB Sound Blaster SBX support
Hello
I just flash my odroid C2 with Coreelec 9.0.1.
I love it !!
I have no problem with sound on HDMI.
But on USB …
I connect a USB sound blaster SBX and I have a terrible noise.
I can hear the sound of the player but I have on top of it some regular “plop” every 0.2 s roughly.
I have setup an SHH connection … but I am a bit lost on where to look at what to run.
I just run aplay -L
CoreELEC:/ # aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=AMLM8AUDIO
AML-M8AUDIO,
Default Audio Device
sysdefault:CARD=AMLM8AUDIO
AML-M8AUDIO,
hdmi:CARD=AMLM8AUDIO,DEV=0
AML-M8AUDIO,
HDMI Audio Output
default:CARD=HD
USB Sound Blaster HD, USB Audio
sysdefault:CARD=HD
front:CARD=HD,DEV=0
Front speakers
surround21:CARD=HD,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=HD,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=HD,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=HD,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=HD,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=HD,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=HD,DEV=0
USB Sound Blaster HD, USB Audio #1
IEC958 (S/PDIF) Digital Audio Output
The same problems with asynchronous USB 2.0 dac. This problem is on all versions, starting with LibreELEC
Is there a workaround?
Something to configure to solve this issue?
I was able to use this sound card with a Raspberry PI + libreelec
THX
For information I solve my problem using the USB on the go and by powering my C2 from the power jack.
Thx
What exactly does USB on the go mean ?
It’s the USB OTG port on the C2.
If you have a look on the below link you can see where its located. Normally they are a mini USB port.
https://wiki.odroid.com/odroid-c2/hardware/hardware
