Hi All,
I am running the latest version 9.0.3 on my C2 and with the help it is finally stable. I do have an issue where my Playlists for some odd reason do not want to load the content (Play It) states the file does not exist.
If i go to the location on the share i can find it and it plays 100%.
Any recommended fixes please.
Thanks in advanced,.
Issues seems to be with Kodi and SFTP.
I had this problem recently when setting up a large buffer (cache) with local files.
@ozolli How did you fix this ?
There is an post of he Kodi GitHub that they have not merged this fix yet. So i take it will just wait for this to get fixed then CoreElec Updated
I reverted the local buffer mode in advancedsettings.xml from
<buffermode>1</buffermode>
to
<buffermode>0</buffermode>
Thanks alot let me give this a try
