Is there anyway to set a resolution of 1680×1050 on the C4 with 9.2.2? Unfortunately I want to use my C4 with a pretty average 22" TV, and while it supports 720p the colors are all washed out (same for all Kodi devices).
I’ve enabled VESA display in CE-settings, and while its added more options, it hasn’t enabled the 1680×1050 resolution.
1680×1050 @ 60hz should be supported by the kernel. It’s possible the display doesn’t advertise the ability to use this mode if it is indeed supported by the display.
create a file called
.kodi/userdata/disp_add
then add the following to it.
1680x1050p60hz
This will add the the 1680x1050 to the list of available resolutions in kodi, whether the display supports/advertises it or not.
Thanks! Worked perfectly.
Does the C4 support 1080p120 - my TV supports it but doesn’t advertise it…
I have used an HD Fury Vertex to spoof my nVidia Shield TV into outputting 1080p120 (i.e. 120fps 1920x1080) and that has played 120fps video content well. (I mastered some stuff with my iPhone shooting at 240fps and remastered it as 1/2 speed 120fps in ffmpeg)
I believe the hardware probably can. However I’m not sure if there is currently support in the kernel for it at the moment.
I will look into it a bit latter today once I’m a more awake. I’m just getting out of bed and crawling towards the coffee maker at the moment.
So unfortunately it doesn’t look like the kernel currently has support for 1080p120.
Thanks for looking and confirming. It’s a niche requirement at the moment I guess - though as 2160p100/120 production ramps up (there were trials at Athletics meets recently - and NHK want 4320p120 as their 8K standard) p120 is going to become slightly more of a thing.
I very much doubt it is going to become a ‘thing’.
There is only 1 4K channel available on Satellite in the UK and it only runs at 50fps, never mind 120fps.
Anyway the VPU can only do 120hz at 1080p, it’s a hardware limitation.
Speaking to those developing UHD broadcast technology - the move to 100/120fps is definitely on the radar in the future. 2160p50/60 simply has too much motion blur for high speed content like sport.
NHK - who developed (or are largely the driving forces) behind our current 1080i HD and 2160p UHD systems are pushing very hard for 4320p120 (i.e. 8k120) with a 2160p120 and 2160p60 downconversion for 8K and 4K sports. They are running a 4K and 8K channel in Japan - and I believe this has included some 120fps trials.
The BBC has worked with the EBU to trial 100fps stuff over the last 6 years or so. It’s not here yet - but it’s definitely on the horizon as a possibility - particularly now we finally have a >60fps timecode standard (which was a real problem and forced dual-phase p50 or p60 to be used)
The move to IP control rooms - rather than SDI-based production facilities - is also a major route to adoption.
Sky may only run a UHD overlay DVB-S2 system - but BT Sport’s multicast IPTV system carries UHD services, the BBC iPlayer does, and the major OTT players for Sport are beginning to as well. Tokyo 2020 would almost certainly have seen a bit of an explosion in UHD sport (as Japan was planning to host at least some of it in 4320p - and some of that was due to be p120 I believe)
