Is the UAS driver present in Coreelec or do I have to install it somehow?
I connected Crucial Mx500 with a UASP adapter and UAS is NOT active when I use the lsusb -t command.
I think it is not supported?
So it can’t be turned on?
Yes, option needs to be enabled in kernel.
CoreELEC-Amlogic-ng.arm-9.2-nightly_vpeter_usb_uas.tar
Great, thank you.
A regular update from the update folder will do?
Yes, exactly like that.
When updating I got: missing (source) KERNEL or SYSTEM. What’s wrong?
Ok, I tried it for the second time and I got:
Kernel md5 failed and system md5 failed.
You must have corrupted file for some reason.
Yes, put file in update folder and reboot.
cd /storage/.update
megadl https://mega.nz/file/eM5yzZ7B#lSpLaXQvfLpLxS3OLADCgTmljzfnBTdbS5BJSw-xqD8
reboot
Ok, it turned out my FTP client corrupted the file and I used a different one to copy the file.
The write tests results:
Without UAS
CoreELEC:~ # dd if=/dev/zero of=/var/media/CR/speed.test bs=1M count=8000
8000+0 records in
8000+0 records out
8388608000 bytes (7.8GB) copied, 35.110141 seconds, 227.9MB/s
With UAS
8000+0 records in
8000+0 records out
8388608000 bytes (7.8GB) copied, 26.322702 seconds, 303.9MB/s
Thanks a lot @vpeter
Can you run this command and post link you get? First please reboot to get clean state. And drive must be attached.
dmesg | paste
Here:
http://ix.io/3LDe
@vpeter will automatic update override your UAS settings? I still get update available notification even though I turned it off.
You need to use my special image if you want to use UAS. Default images doesn’t have enabled.
Ok, that’s what I thought. Thanks.
@vpeter would it be too much if I asked you to concoct a UAS enabled version of Matrix stable version for Odroid C4 like the one you did with 9.2.8 version for me before? Thanks.
Here it is.
Thanks a lot, much obliged.
