Running stable ng 20.3 on my Odroid C4.
I purchased a case and fan for my Odroid C4. I noticed that there are no settings to control the fan in CoreELEC settings. Is this because the ng kernel doesn’t support it?
My Khadas VIM1S running ne 20.2 has such settings.
Because Khadas VIMs use a external MCU to control such feature.
For Odroid you will need to make device tree changes. You can pick them from this draft:
It should be ok to just copy paste this part to your unique DT and compile it. Just adjust the GPIO for your pin used.
Thank you.
