Hi, I got SPDIF optical output on N2 + (via GPIO), I only run coreelec. Everything works great, only if coreelec goes to sleep and wakes up, SPDIF output will not start. I have to restart the whole board (restarting Coreelec is not enough). Don’t know how to solve it? Thanks
Don’t let it go to sleep?
It consumes so little in idle that it’s not worth the bother to put it to sleep…
According to the manufacturer of SPDIF Toshiba, the optical output is not built for continuous operation
What does that mean, where are those specifications?
If it means that it should not be powered on all the time, that’s a nonsense, because ALL SPDIF transmitters in cheapest Chinese boxes are powered all the time, as are all SPDIF receivers in all AV receivers.
If it means that it should not transmit all the time, why should that worry you, since I’m sure that you don’t listen to music 24/7…
