Odroid N2 Alternatives?
Hi, Does anyone know of a good alternative to Odroid N2 with a working power on button and atleast 2 usb ports.
I play my movies from powered usb drives. I like to be able to play UHD files with Atmos and DTS HD etc
It needs to be Refresh rate switching capable so I dont have to do anything manually.
Also with good quality onboard dac like the odroid
Ethernet port is also required.
I previously had a vero 4k+ but found it alittle lacking with the number of usb ports and dont want to run an extra usb hub
I don’t need dolby vision support.
I am looking into all the hardware supported by coreelec like the beelink etc but not sure if anything better does exist than the odroid n2 for coreelec.
Rick
A smart plug would be cheaper than a replacement.
