I pushed a fix, hopefully tonight’s build will completely fix the issue. Let me know.
Updated to 20190717 nightbuild, The issue has been fixed,Thank you!
Where do I find this vfd.conf file for the N2? I found only the name but not the file itself:
odroid-n2-ssd1306-12832-i2c-vfd.conf
Thanks!
I do have two questions:
- Does the OpenVFD or the Odroid N2 OLED service plugin show the remaining time fow livetv (EPG)?
- Why the brightness doesn’t change if changed in the OpenVFD settings?
- OpenVFD doesn’t support it, because Kodi doesn’t provide this information.
- Not sure, it should work.
Isn’t point 1 covered by these info labels in particular the 3rd one?
| PVR.EpgEventDuration[(format)] | Returns the duration of the currently played title on TV. See ListItem.Duration for optinional formatting options |
| PVR.EpgEventElapsedTime[(format)] | Returns the time position of the currently played title on TV. See ListItem.Duration for optinional formatting options |
| PVR.EpgEventRemainingTime[(format)] | Returns the remaining time for currently playing epg event. See ListItem.Duration for optinional formatting options |
| PVR.EpgEventFinishTime[(format)] | Returns the time the currently playing epg event will end. See ListItem.Duration for optinional formatting options |
Yes, but what happens when the EPG is not available?
Also this is for skins, I’m not sure it’s available for addons. I’m pretty sure I tried it and couldn’t find a way to get the EPG.
I’m not really sure, I don’t use the live TV or the EPG functions of Kodi as I have no tuner. But as far as I know any skin info label can be accessed in python using xbmc.getInfoLabel() so I’m not sure why the PVR / EPG info labels wouldn’t also be accessible.
20190811 nightbuild makes OLED not working ,
dmesg
[ 10.810531@2] OpenVFD: Version: V1.3.0
[ 10.810538@2] OpenVFD: vfd_gpio_clk: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810540@2] OpenVFD: vfd_gpio_dat: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810542@2] OpenVFD: vfd_gpio_stb: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810544@2] OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810546@2] OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810547@2] OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810549@2] OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.810551@2] OpenVFD: vfd_gpio_protocol: #0 = 0x01; #1 = 0x02;
[ 10.810553@2] OpenVFD: vfd_chars: #0 = 0x00; #1 = 0x01; #2 = 0x02; #3 = 0x03; #4 = 0x04;
[ 10.810556@2] OpenVFD: vfd_dot_bits: #0 = 0x00; #1 = 0x01; #2 = 0x02; #3 = 0x03; #4 = 0x04; #5 = 0x05; #6 = 0x06;
[ 10.810558@2] OpenVFD: vfd_display_type: #0 = 0x1F; #1 = 0x3C; #2 = 0x00; #3 = 0xFD;
[ 10.810561@2] OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
[ 10.810562@2] OpenVFD: Skipping vfd_gpio_clk evaluation (0xFF)
[ 10.810563@2] OpenVFD: Skipping vfd_gpio_dat evaluation (0xFF)
[ 10.810564@2] OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
[ 10.810564@2] OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
[ 10.810565@2] OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
[ 10.810566@2] OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
[ 10.810567@2] OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
[ 10.810769@5] OpenVFD: Select SSD1306 controller
[ 10.810774@5] OpenVFD: HW I2C interface failed to intialize. Could not get I2C-2 adapter
[ 10.810776@5] OpenVFD: Failed to initialize the controller, reverting to Dummy controller
I2C-2 hardware was disabled in DTBs.
We switched to I2C-3 in hardware. I’m not sure whether we’ll change this for the N2 yet, but for now you can try this config file.
odroid-n2-ssd1306-12832-i2c-vfd.conf (2.0 KB)
still not working
dmesg
[ 10.879653@3] OpenVFD: Version: V1.3.0
[ 10.879659@3] OpenVFD: vfd_gpio_clk: #0 = 0x00; #1 = 0x53; #2 = 0x00;
[ 10.879661@3] OpenVFD: vfd_gpio_dat: #0 = 0x00; #1 = 0x52; #2 = 0x00;
[ 10.879663@3] OpenVFD: vfd_gpio_stb: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.879665@3] OpenVFD: vfd_gpio0: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.879667@3] OpenVFD: vfd_gpio1: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.879670@3] OpenVFD: vfd_gpio2: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.879671@3] OpenVFD: vfd_gpio3: #0 = 0x00; #1 = 0x00; #2 = 0xFF;
[ 10.879673@3] OpenVFD: vfd_gpio_protocol: #0 = 0x00; #1 = 0x00;
[ 10.879675@3] OpenVFD: vfd_chars: #0 = 0x00; #1 = 0x01; #2 = 0x02; #3 = 0x03; #4 = 0x04;
[ 10.879678@3] OpenVFD: vfd_dot_bits: #0 = 0x00; #1 = 0x01; #2 = 0x02; #3 = 0x03; #4 = 0x04; #5 = 0x05; #6 = 0x06;
[ 10.879680@3] OpenVFD: vfd_display_type: #0 = 0x1F; #1 = 0x3C; #2 = 0x08; #3 = 0xFD;
[ 10.879683@3] OpenVFD: Detected gpio chips: periphs-banks, aobus-banks.
[ 10.879686@3] OpenVFD: “periphs-banks” chip found. base = 410, pin count = 86, pin = 83, offset = 493
[ 10.879687@3] OpenVFD: “periphs-banks” chip found. base = 410, pin count = 86, pin = 82, offset = 492
[ 10.879688@3] OpenVFD: Skipping vfd_gpio_stb evaluation (0xFF)
[ 10.879689@3] OpenVFD: Skipping vfd_gpio0 evaluation (0xFF)
[ 10.879690@3] OpenVFD: Skipping vfd_gpio1 evaluation (0xFF)
[ 10.879691@3] OpenVFD: Skipping vfd_gpio2 evaluation (0xFF)
[ 10.879691@3] OpenVFD: Skipping vfd_gpio3 evaluation (0xFF)
[ 10.880781@0] OpenVFD: Select SSD1306 controller
[ 10.880857@0] OpenVFD: SW I2C interface failed to intialize. Could not establish communication with I2C slave
[ 10.880859@0] OpenVFD: Failed to initialize the controller, reverting to Dummy controller
It would be awesome if the display would show the information from the EPG (if available). I use liveTV in 98% of the time. In case it doesn’t work, I added only a clock to my N2, which at least for me, is not really something useful.
Yes, The OLED is working again, thanks
I updated 20190811 nightbuild after dont work openvfd with ssd1309. But odroid n2 oled addon work with ssd1309
Just read back a few reply.
I use k1 pro. N2 oled addon works perfectly with coreelec but openvfd add no work
I can’t know what the problem is without any logs. This is also offtopic.
Why has it been disabled?
