I just received a Odroid N2 this morning and for reasons I wont bore anyone with I need to extract the serial number, however none of the Linux commands I have tried through SSL will work and the inxi utility I would normally use isn’t on entware. Does anyone know how to do this?
What exactly do you mean by extract?
If you want to read it then
cat /proc/cpuinfo | grep 'Serial'
If you mean remove it or change it then I don’t know if you can.
That’s the command I needed thanks, I didn’t need to do anything with it just record the serial number for insurance purposes.
