My box has been working flawlessly for years, except for one random issue I could not solve, until today. I’d like to share the resolution in the event someone else goes through this issue, in the future.
After a random reboot, I’ve been experiencing a problem where my personal Kodi build/Skin would not load. All that would appear on the screen was the CoreELEC logo and nothing else. I knew the issue was with the GUI not loading properly as I was able to access files via samba and ssh with no problems.
Please note, I experienced this problem using Stable versions and Nightly versions of CoreELEC to no avail. Kodi would work fine for a few days and then suddenly, after a random reboot, the issue would reappear.
The culprit for sure was my custom Skin - Xonfluence. The problem would NOT happen when using the default Kodi skin as I tested this theory for weeks.
After reviewing the Kodi logs, I noticed the following error:
SQL: [Textures13.db] SQLite error SQLITE_ERROR (no such table: version)
Somehow, my Textures13.db file (located in .Kodi/userdata/Database) is being corrupted.
Simply deleting this file and rebooting CoreELEC solved my boot issue.
Now, I have to look further into what’s corrupting the file in the first place. Could it be my cache cleaner set to run on each boot? Will report further findings…
