I’m about to order an Odroid N2.
Can I transfer movies from Windows to external drives (NTFS formatted) connected to USB hubs, which are then connected to the N2?
Yes you can, that’s how I mostly use it…
I mean, I can transfer movies through the network?
I’m doing exactly this, 1TB hdd is connected to the TV Box and serving as a file server.
However ntfs-3g driver for NTFS disks causing high CPU load on TV Box.
So I’m using Ext4 as file system
I am using an 8TB NTFS drive, i can drag and drop files from my pc to the N2 and vise versa, very fast to, i love it.
And also play files direct from the pc drive tis good
