the original version of petitboot is not compatible with CE as it doesn’t support windows partitions
-later versions of petitboot may not support your TV’s native screen resolution and will have unreadable text
My conclusion is that petitboot is still a work in progress and its far easier to simply use the preinstalled CE SD and that is the only format that CE offers support for.
Is it also possible to take a USB 3.0 stick instead of eMMC?
For the CE Edition, CoreElec is preinstalled on the mSD. I want to install Android on the USB stick.
When starting I want to be able to select between Android and CE.
Naturally CoreElec should serve as standard.
I do not know how it works with Petitboot. I’m not so good at English either.
Maybe someone would be willing to help me.
Yes you can use a USB stick instead of using a eMMC when booting via Petitboot.
But booting via Petitboot is slower than booting direclty off the eMMC.
I have always used IMAGE2USB or Etcher or Libreelec installer.
I have to use Etcher for full compatibility?
For CoreElec on USB or SD card also Etcher?
Same for Android on USB or SD card Etcher?
Of course I would prefer either Android on USB and CoreElec on SD, or the other way around.
I have to say that I have no eMMC at home. That’s why I wanted to use a USB 3.0 64GB for (Android, CoreElec) and mSD for (CoreElec, Android).
