Opensubtitles.com plugin
The OpenSubtitles.com plugin is not working and keeps reporting an incorrect password, even though I’m certain the credentials are correct. The OpenSubtitles.org plugin works without any issues using the same setup.
Has anyone experienced this problem before? What is the best way to fix it? Are there any known authentication or account-related issues with the OpenSubtitles.com plugin that could cause it to reject valid login credentials?
this the the CoreELEC support forum, not the opensubtitles . com plugin forum
locate the support for your addon
The .org isn’t working for a year I guess because they switched to a commercial system!?
Use .com, it works same.
As it would appear that opensubtitles.org requires a VIP (paid) membership to download subtitles via API, and that opensubtitles.com allows downloading subtitles for free.
