I tried to build Coreelec 21 but the build process stops at building u-boot for Odroid_N2 . The culprit is the Makefile at u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558 : it tries to parse the built acs.bin and the file “parse” does not exist.
I never heard it is necessary to parse the built acs.bin and no one mentions it at this forum or internet. Can somebody have a look at this issue please ?
My build steps :
- git clone Coreelec
- git checkout coreelec-21
- PROJECT=Amlogic-ce DEVICE=Amlogic-ng ARCH=arm64 make
Just run DEVICE=Amlogic-ng make
and try again. Best a make clean
before.
Thanks for the tip. Unfortunately , after make clean and run the cmd. you suggested , the problem is still the same :
LD examples/standalone/libstubs.o
CC examples/standalone/hello_world.o
LD examples/standalone/hello_world
CC examples/standalone/atmel_df_pow2.o
LD examples/standalone/atmel_df_pow2
OBJCOPY examples/standalone/hello_world.srec
OBJCOPY examples/standalone/atmel_df_pow2.srec
OBJCOPY examples/standalone/hello_world.bin
OBJCOPY examples/standalone/atmel_df_pow2.bin
LDS u-boot.lds
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot.bin
OBJCOPY u-boot.hex
DEPS /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.d
DEPS /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs_entry.d
DEPS /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.ld.d
Building board/hardkernel/odroidn2/acs.bin
CC acs.c
AS acs_entry.S
PP acs.ld.S
LD /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.elf
OD /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.dump
BIN /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.bin
Built /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.bin successfully
make[2]: /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/fip/parse: No such file or directory
make[2]: *** [/home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/Makefile:871: /home/ubuntu/CoreELEC/build.CoreELEC-Amlogic-ng.arm-21/build/u-boot-Odroid_N2-43d26e1865333916d7889a586948e11b83b2c558/build/board/hardkernel/odroidn2/firmware/acs.bin] Error 127
make[1]: *** [Makefile:147: sub-make] Error 2
ESC[1;31mFAILURE: scripts/build u-boot-Odroid_N2:target during make_target (package.mk)ESC[0m
*********** FAILED COMMAND ***********
DEBUG=${PKG_DEBUG} CROSS_COMPILE=aarch64-elf- ARCH=arm CFLAGS="" LDFLAGS="" make HOSTCC="$HOST_CC" HOSTSTRIP="true"
${SCRIPTS}/build "${1}" "${PARENT_PKG}"
ESC[1;31mFAILURE: scripts/install u-boot-Odroid_N2:target has failed!ESC[0m
[133/363] [FAIL] install u-boot-Odroid_N2:target
Parallel build failure - see log for details. Time of failure: Sat May 10 15:40:02 HKT 2025
make: *** [Makefile:7: release] Error 1
I personally think the Makefile ( Makefile - Pastebin.com may be the problem : please refer to line 871.
If you need more info. , please do not hesitate to let me know .
Regards !
Xiaohai
For ce-21 best use Ubuntu 20.04.
For CE-22 better Ubuntu 22.04.
I’m buidling both CE-21 and CE-22 on Ubuntu 24.04.2 LTS.
Must be something on your distro.
Or to start from fresh
rm -fr build.CoreELEC-Amlogic-ng.arm-21
