sachb
25 June 2021 15:45
1
I can’t seem to use the Netflix on coreelec now even after using the authentication key. I enter the pin and on the next screen it asks for my Netflix password, I enter the correct details and it shows PASSWORD ENTERED did not match
Maybe try uninstall / reboot / reinstall / re-authenticate and see if that fixes the issue?
Can you login with same email/password with any browser on a Windows PC?
Do you use any special characters in your password?
sachb
26 June 2021 04:12
4
Yes, I can log in with the same email & password on a normal browser but not on Coreelec’s addon.
This is not a CoreELEC issue, it’s an add-on issue which will be fixed in the future.
opened 06:26PM - 04 Mar 20 UTC
Ignored rules
Resolution: Workaround applied
## Bug report
since 7 days I cannot login to the Netflix plugin :"passw… ord incorrect"
I tried login/password on a different system : it is working
I tried to reinstall libre elec and everything, same issue.
Thank you
#### Your Environment
- Netflix add-on version: <!--- e.g. 14.1 -->0.16.4
- Operating system version/name: <!--- e.g. Windows 10, LibreElec 9.0, etc... -->libre elec.9.2.0
- Device model: <!--- if appropriate -->raspberry pi 3+
Used Operating system:
* [ ] Android
* [ ] iOS
* [ ] Linux
* [ ] OSX
* [x] Raspberry-Pi
* [ ] Windows
### Describe the bug
### Debug log
<!--- How to:
1) Go to add-on settings, in Expert page and change "Debug logging level" to "Verbose"
2) Enable Kodi debug: go to Kodi Settings > System Settings > Logging, and enable "Enable debug logging"
3) How to get the log file? Read Kodi wiki: https://kodi.wiki/view/Log_file/Easy
RESPECT THE RULES!
- A DEBUG LOG IS ALWAYS MANDATORY WHEN CREATING AN ISSUE. PROVIDE A LINK TO THE LOG!
- DO NOT PASTE THE CONTENT OF THE LOG HERE
- DO NOT CUT THE LOG
- If the log file is really huge (more 1Mb) in Kodi settings disable "Component-specific logging" then create a new log
The debug log can be found from this link:
# To new users with Incorrect password problem
A new login system has been added,
is called "Authentication key"
**In the readme all the information**
https://github.com/CastagnaIT/plugin.video.netflix#login-with-authentication-key
~A new login solution is in test, will be released next days~
~The test files are on this comment:~
~https://github.com/CastagnaIT/plugin.video.netflix/issues/502#issuecomment-684824673~
~I suggest instead to use the test, to wait for the new release~
This addon respects the same rules used in the Kodi forum
https://kodi.wiki/view/Official:Forum_rules
therefore the single violation will eliminate your request
You are pointing to a thread more than a year old. Since then it was resolved with new addon updates. There are no new reports with this problem…
The issue with the addon is not resolved, it is still open and basically the final comment is referring users with this issue to a workaround – which is using the authentication key method. See GitHub - CastagnaIT/plugin.video.netflix: InputStream based Netflix plugin for Kodi for tips on how to use the authentication key method.
Apparently the issue is in some regions the email/password authentication requires a captcha which is not handled by the addon, you can see more about that at:
Indeed, the link is older but the problem is current again, 2 weeks of not working user / password login. Not fixed, there is a new request to log in with user/passw:
CastagnaIT:master ← CastagnaIT:http2
opened 06:21PM - 25 May 21 UTC
### Check if this PR fulfills these requirements:
* [x] My changes respect the … [Kodi add-on development rules](https://kodi.wiki/view/Add-on_rules)
* [x] I have read the [**CONTRIBUTING**](../../master/Contributing.md) document.
* [x] I made sure there wasn't another [Pull Request](../../../pulls) opened for the same update/change
* [x] I have successfully tested my changes locally
#### Types of changes
- [ ] New feature (non-breaking change which adds functionality)
- [x] Feature change (non-breaking change which change behaviour of an existing functionality)
- [ ] Improvement (non-breaking change which improve functionality)
- [ ] Bug fix (non-breaking change which fixes an issue)
- [ ] Breaking change (fix or feature that would cause existing functionality to change)
### Description
**This is currently experimental**
Last year the website is migrated to the HTTP/2 protocol
currently the web session is managed by the Requests module which does not support HTTP/2
This PR introduces the use of the HTTPX module, although the HTTP/2 support is still under development in this module seems to work well.
I think that the HTTPX module is the most up-to-date HTTP/2 module of this moment.
The HTTPX package is not provided with Kodi and is unlikely to be included for our request, because this add-on has not been approved for Kodi repository, it could be added if other approved add-ons will use this module,
in the meantime, you will need to include it as internal package including all dependencies and subdependencies.
This PR provides a first solution to this future problem and i think that this PR will not be included in the master branch until the current HTTP1.1 protocol will cause other problems with the endpoints or the website discontinue the support.
**TODO List:**
- ~To check if all dependencies and sub-dependencies of each module are in place~
- ~Check cookies code~
- ~Check TCP keep-alive communications~
- ~To implement close session on addon closing~
- Although HTTPX imitates Requests with similar properties/arguments a quick recheck of each method is needed
- Test all endpoints (currently tested: login, main menu and playback)
- ~Test standard login on various systems to ensure no regressions (to check if "Incorrect password" error will be fixed or worsened)~
- Investigate for error: `httpx.RemoteProtocolError: <ConnectionTerminated error_code:ErrorCodes.COMPRESSION_ERROR, last_stream_id:2147483647, additional_data:485041434b202d20696c6c6567616c20696e6465>`<br/>happen only sometimes and after playing multiple videos, ATM cause not know, could be also an httpx bug (https://paste.kodi.tv/iyubevuxey) (UPD 23/06/2021 after updated all sub-deps seem there is no more errors at least on Windows)
**From my tests this PR seem to fully fix the user+password login issues,
i have tried test logging several times on Windows, Linux Mint, CoreELEC with the result of 100% login success,**
hoping it is not a coincidence it would be helpful if someone report login test feedbacks
This issue is an add-on issue, not CoreELEC or Kodi.
system
Closed
26 September 2021 14:23
9
