Lately I have been noticing the issue that the sound and picture is out of sync. Hence I decided to upgrade the Coreelec version. I chose RC Firmware Update v0.4.2 for Ugoos AM6 & Cube X2/X3 models (https://ugoos.com/rc-firmware-update-v0-4-2-for-ugoos-am6-cube-x2-x3-models), specifically the version “AM6_dce_0.4.2”
However even the later Core-Elec isnt fixing the issue.
I tried paying Bluray rips, remux or m2ts files there is still a small delay which is frsutrating
The dual boot firmware is not official supported by CoreELEC.
So flash a “normal” Android on the device and boot from uSD/USB and try again with a fresh CE install.
And I think this 0.4.2 firmware is encrypted so you will not be able to install to internal memory.
Hi @Portisch I successfully installed 0.4.2 into internal memory.The ugoos team helped me do that. As per their instructions I first installed encrypted AM6_dce_0.3.9. And from there installed 0.4.2
Im able to boot to 0.4.2.
Its just the slightly out of sync voice and picture
