PlexKodiConnect - TV Shows will not 'Play from Beginning' while marked as in-progress
When a TV episode is in progress, choosing the “play from beginning” option resumes the episode instead. The same feature works without issues when playing movies. Does anyone else have this issue when using PlexKodiConnect on CoreELEC?
I just spun up a Windows 11 VM with Kodi 21 running on it and the “Play from beginning” works fine on TV Episodes. So not sure if this is a CoreELEC issue or an issue with the plugin. I opened a BUG (TV Shows will not 'Play from Beginning' while marked as in-progress · Issue #2094 · croneter/PlexKodiConnect · GitHub) to get clarification from the author, but no response. Log file is attached under that github page.
