When will it be available in stable release? I have only installed the stable.
As soon as TK release Kodi 19.2
Addon could be found here:
https://relkai.coreelec.org/?dir=addons/19.2/Amlogic-ce/arm/pvr.teleboy
The Add-on didnât work anymore because of Missing DRM key.
It was now updated to a newer version: GitHub - rbuehlma/pvr.teleboy: Kodi PVR-Addon for Teleboy
It is already available at the kodi repo.
Can you please update it too?
Regards
Damian
Have you tried updating the addon from here?
No, I think it has to be migrated to coreelec otherwise coreelec would reference to kodi repo which is not the case
I tested it, it doesnât work
@vpeter
you have been so kind in the past and provided the newest Version of the addon: Releases ¡ rbuehlma/pvr.teleboy ¡ GitHub.
The developer updated ist 9 days ago and from now on the addon doesnât work with the older version anymore.
May I ask you, to compile the current Version for me?
Best regards
Damian
Amlogic-ng version: 513.8 KB file on MEGA
For Amlogic I donât have build at hand but I can make it.
That would be great
Wait, Matrix is only ng so the above addon is correct.
From what I see CE repo already has this version included?
Unfortunately not. It canât choose it
Ok, which CE image you are using? Maybe I missed something. I assume CE 9.2.8 ? Because CE 19 has it.
Is it possible, to update the Teleboy addon to the newest version 20.3.3 (Nexus). The existing version doesnât work on the official Nexus version. Thank you.
Now it works. Thank you very much.
Until August 1st, the Teleboy plugin also worked on the CoreElec 22 (NO) image. With later images, an error message appears stating that the plugin is no longer compatible.
Is it possible to update the Teleboy addon to the latest version 22.1.0 (Piers).
Addon needs to be bumped but also kodi needs to be bumped. Will take few days.
You can try this one: 640.2 KB file on MEGA
Thank you, works perfect.
