Hi all,
Is there a way to prevent an Odroid N2 from shutting down when the TV (2019 Samsung) is switched off ?
I don’t use CEC (CEC adapter in Settings/System/Input is switched off) because it’s messy and often breaks the whole CEC chain.
I use the Samsung Universal Remote function to control the N2 via IR.
It works well this way but it shuts down the N2 every time the TV is switched off.
I would like the N2 to stay on at all times.
I know there is an option for this in the CEC settings but since it’s turned off, it shouldn’t matter, right ?
Thanks in advance for the help !
Djon
19 May 2022 06:01
#2
I got one of these and now it doesn’t turn off anymore:
roidy
20 May 2022 16:04
#3
Try overriding the power key in your keymap.xml, change it to a noop to prevent the IR remote from powering down the N2
<keymap>
<global>
<remote>
<power>noop</power>
</remote>
<global>
</keymap>
Thanks roidy.
I actually found a workaround with the Samsung Universal Remote function : when I set it up, it gives you a few tries to control the device via IR (probably different IR methods in case one doesn’t work).
If I validate the first try, it will shut down the N2 every time I switch off the TV.
If I say the first try doesn’t work and I validate the second try, it never shuts the N2 down.
Go figure… anyway, it will do just fine for now !
I have been using this for a long time to prevent CoreELEC/LibreELEC from shutting down:
# only once (from SSH) survive the reboot
systemctl mask poweroff.target suspend.target kodi-poweroff.service
systemctl restart systemd-logind.service
