Pro help needed_how to configure ir wakeup code on wetek hub
Hi guys,
in short i am running coreelec 9.2.8 old version on the wetek hub. I am really happy with this version.
I want to use the wetek play 2 remote control on the wetek hub. Both are IR remote controls. Everything works fine on the wetek play 2 remote control except the power on button! Power off works fine !
Both remote controls are from the same company. The stock remote on the hub has no numbers to enter. I need number like on the wetek play 2 control.
How to configure it to get it running?
Need some pro’s help.
Thanks in advance.
https://wiki.coreelec.org/coreelec:rcu#ir_wakeup_feature
Which step do i need to follow? I need to configure the power on button to get it working on my wetek hub.
This hidden menu is by default on 9.2.8 not shown. Will it be visible after deleting the config file?
before i go to the next steps
https://wiki.coreelec.org/coreelec:bl301#supported_soc
is it really so complicated?
When the device is suspended/powered off, most of SOC is off as well, and specific hardware is needed to bring the SOC back online. It’s more complicated than it seems.
There is built in functionality to power on from CEC, WOL, RTC, and IR, and the bl301 injection tool allows power on through that hardware to be leveraged. But I doubt IR power on through USB will work?
Could someone tell me if it can be work with the soc of wetek hub?
